Adjustable Master
Old Jan 22, 2006 | 11:35 AM
97MysticZ's Avatar
What's a Sticky?
Default Adjustable Master
I know that the Mcleod Adj. Master can be used on an LT1 car, I assume that the Ram model is the same? Are there any LT1 guys out there who are actually using one of these? How is it working for you and do you like it? Also, if your compident enough to install the actual clutch, is installing this part relatively easy? Thanks guys.
