Best Cam To Run In A 383 Stroker?
The cam will need to fit your goals and use of the car.
LaZer cams out of Nashville ground mine.
I went with a 218/222 .544/.538 112lsa in my 396. We picked the cam when my car was still a daily driver and I wanted civil street manners. It has ran in the 11.6's @119 NA and 10.9's @ 127 on a small shot of nitrous. Now that the car is a track only car I called LaZer back and went back over my goals with him and will be changing to a 24x/25x .6xx/.58X.
Cam choice is not cut and dry as to which one to go with. Find a cam grinder that you like. Tell them what you want from the car and trust their opinion.
It depends on alot of different factors.. If your not comfortable considering all the specifics and finding a cam to best suit all of them, its best to leave the decision to an experienced proffesional.
Harol @ Port Pros will take care of you and spend the time to explain why he chose what.
