trouble code
Oh well... First things first, I would remove the MAF sensor and clean it with brake parts cleaner / electronics parts cleaner, and inspect the electrical harness for corrosion. If that doesn't help it, then you need to do some testing with a volt meter. We can go further into this if you need.
