1993 corvette to mass air conversion?
Old Jan 30, 2006 | 07:28 PM
PurpleHaze98's Avatar
Default 1993 corvette to mass air conversion?
What would i need and would this be a fairly simple project, and yes i have tools and can work on cars. i have the opportunity to buy a 93 vette and wanna do mass air.
Thanks
Tom
Old Jan 30, 2006 | 08:23 PM
Tony Shepherd's Avatar
All you will need is a 94-95 pcm and harness, ignition module, TPS, IAC, and a little wiring for the fuel pump feed, ALDL signal communication wire, and a little time.
Old Jan 31, 2006 | 02:55 PM
Camaroholic's Avatar
Don't forget heated 4-wire O2's, and you'll likely want both factory service manuals (a '93 and a '94 or '95), so that you can check your wiring. Factory manuals are worth their weight in gold when you get neck deep in wire.
IMO it's not really worth it... lots of work (and $$) for... what?
