Cam Advice Needed
Old Jan 31, 2006 | 03:13 PM
FHawk365's Avatar
Default Cam Advice Needed
Hello everyone,
I own a 1995 Firehawk with all the options available form SLP. Recently I had a lifter bearing fail and score the lobe on the cam. As a result I now have a reason to replace the cam. Dose any one have any recommendations for a good replacement cam, valve springs, and rocker arms? How much RWHP gain should I expect after the aforementioned modifications?
(Other than the options installed by SLP the car is completely stock.)
Old Jan 31, 2006 | 03:34 PM
MrBill97396's Avatar
Well you have alot of options, are you going to put heads on the car also or just a cam? There will be 9 million suggestions on here.
Old Jan 31, 2006 | 03:46 PM
slowmofo's Avatar
yeah, it all depends on what you want to do with the car. if your gonna leave it relativley stock, mabey a stock replacement is good. if you mod alittle something alittle bigger... tons of options.
Old Feb 1, 2006 | 04:47 PM
FHawk365's Avatar
I'm not going to be doing any heavy modifications in the near future. I just figured since I have to replace the cam I might as well upgrade it. I would like to see 315-330 RWHP after the swap and a good tune.
