Car still won't shift!
Old Feb 8, 2006 | 01:46 PM
Togo's Avatar
so it doesn't shift from 1st to 2nd? or it doesn't shift from 2nd to 3rd?
i just got my car back from the trans shop as it wouldn't shift from 2nd to 3rd (92 vette LT1 700R4 - not sure if it's the 4l60E or NOT)
turns out there was a hairline crack in the lockup solenoid
you really should plug a code reader into your car and determine if everything is operating soundly - check TPS voltage - however, if it wasn't in "range" then you should have a code.
i also don't know about the 94 trans in Fbody - but the 92 uses a TV cable (so perhaps mine is NOT a 4L60e but rather just a 4L60) does yours use a TV cable also? maybe that is out of adjustment?
Old Feb 8, 2006 | 03:18 PM
A-man930's Avatar
No, the car will shift, just not at WOT, and it's between every gear. Shouldn't a check engine light be on if there were a computer problem? Even so, we'll take it up to Autozone and have them plug it in, I'm supposed to look for low voltage on the TPS, anything else?
Old Feb 10, 2006 | 09:56 PM
Mean94t/a's Avatar
So i was going to take my car to autozone to see if it is throwing any codes but...now it won't even start. What the hell. before i had my opti replaced it started every time. any idea what the hell is going on under my hood?
Old Feb 10, 2006 | 10:08 PM
383LT1S10's Avatar
I dunno, sounds hopeless, I will buy it for scrap prices from you since you seem like a good guy
Old Feb 11, 2006 | 07:55 PM
Mean94t/a's Avatar
haha, alright i'll sell it all to you for 4500 no kidding, it's your's. I just want to get rid of it so i can get this newer ls1 ta.
Old Feb 11, 2006 | 10:31 PM
HeapaShifter's Avatar
Does it spin over or not start at all.
Since you had the optispark replaced and it didn't happen before, you might have a spark problem. One of the wires might not be pushed on all the way or something like that.
Or it could be something like a vacuum line not hooked back up or a sensor not plugged back in all the way. You should check all these things before introducing new things in as problems.
I had a 98 3.8 camaro that I thought can tranny problems because it was stumbling under hard accelerations. It turned out to be a spark plug. You are sure all of your plugs and wires are good.
Old Feb 11, 2006 | 11:17 PM
Mean94t/a's Avatar
I'll check them tomorrow, missouri weather permitting. thanks for the suggestions, keep um comin'.
Old Feb 11, 2006 | 11:18 PM
383LT1S10's Avatar
haha sorry i was kidding man. I will have about 10k sunk into this S10 by fall so no spare cash here!
Old Mar 14, 2006 | 10:09 PM
Mean94t/a's Avatar
Thanks guys for all your help, i have great news. I spent 6 hours yesterday changing the plugs, wires, throttle postion sensor, ignition coil, and ignitions control module, but those 6 hours were well worth it! The car runs perfect, i'm not sure exactly what it was but i do know that it wasn't the plugs or wires cause they were all in great condition, my guess is that it was the ignition control module. Either way it runs awesome, it doesn't studder from a launch, and a it shifts impeccable at WOT! Thanks again to everyone who offered advice!
Old Mar 15, 2006 | 10:15 PM
PunishedU's Avatar
I'm pretty sure it was the throttle position sensor. Mine went bad a little while ago and it when driving it would not shift right and was very jerky. Replaced that and its been fine ever since.
Old Mar 16, 2006 | 09:16 PM
Mean94t/a's Avatar
Yeah i def. think that was one of the main issues, but seeing at the end there that it wasn't even starting and supposedly the ignition control module's go bad often, it think that was a huge part as well.
Old Mar 19, 2006 | 09:49 AM
  #32
A-man930's Avatar
Hold on a minute there pal, you mean WE spent six hrs. and you didn't have to get up for work two hrs. after! lol
Wow, 6 hrs. can do a number on your nuckles! Judging by the way the old TPS sensor felt compared to a new one, I imagine the shifting problem was due mostly to it. The starting problem however was probly the ICM, and hell, now it's got a new coil too. Anybody want to come and help us with the passenger side plugs & wires?
