Those of you with the Delteq ignition
Old Feb 6, 2006 | 04:42 PM
Boz95z's Avatar
Default Those of you with the Delteq ignition
I was wondering if you guys like it? Also, what do you do with your Opti? Do you take it off? I also have a MSD 6-AL box that I assume I would not need if I got this kit. I also have a Crane PS-91 coil on the car as well. Would all that equipment be obsolete? I also would like to know if the Opti has to be in working order to use the kit. Any info would be greatly appreciated.
Old Feb 6, 2006 | 09:19 PM
Formula WS6's Avatar
Yes your opti does need to be in working order. The delteq basicly deletes the single coil/module, cap, rotor and gets replaced with an ignition module and coil setup from a northstar cadillac. There is also a conversion module that takes the place of the stock coil/module.
And yes, I am very happy with it.
