SB2.2 heads on standard block
Old Feb 12, 2006 | 02:39 PM
wrenchman2300's Avatar
Default SB2.2 heads on standard block
Has anyone used SB2.2 heads on their LT1 block and/or know if you need a certain type of cam? I know the SB2.2 block has different lifter angles and locations so if any one knows exactly what type of lifters to use on the LT1 block with those heads let me know.
Old Feb 12, 2006 | 04:58 PM
BizZzatch350's Avatar
Moderator
N20Dave should be able to chime in as he did the swap on to a stroker LT1
