How many of you use Meth?
Old Feb 12, 2006 | 11:14 PM
SS14PSI's Avatar
Default How many of you use Meth?
Hey Hey no junkies in here either! How many of you LT1 folks use meth injection. I'm looking at kits now and appreciate any pics/info about the LT1 meth kits.
Old Feb 12, 2006 | 11:18 PM
streetrod93's Avatar
don't you know people wake up dead from **** like that?
just kidding man.
i don't know of too many people that use methanol injection. if you're looking for something down that route, in myt opinion it would be hard to walk away from good old nitrous. there's so much tech help already out there and parts are everywhere. looking at your signature, about a 100 shot through that procharger would most likely wake things up a little
Old Feb 12, 2006 | 11:32 PM
Dragframe's Avatar
Yeah... if you are looking for a good way to cool your intake charge without making life harder on your motor (like nitrous would) i would go with a good water/meth injection. I personaly have no used it, but that gains that canbe seen from a simple meth kit are incredible... and you can run a decent amount more boost on meth.
Old Feb 12, 2006 | 11:35 PM
lt1taracing's Avatar
not sure what effect it would have on the pump and injectors. i'm sure it would run lean considering the burn rate. i've heard converting to methanol on a carb. car is worth around 30hp. and it tends to run around 20 degrees cooler and also burns cleaner. their is a highly oxegen enriched racing fuel that i've heard claims of 12hp over reg. racing fuel. kinda expensive tho. had a friend run it in his hybusa and saw an improvement. i dont think you would want to run nitrous with it tho.
Old Feb 12, 2006 | 11:37 PM
sorry, after reading your post again i realized you just wanted a kit not convert to methanol completely.
Old Feb 12, 2006 | 11:45 PM
Dragframe's Avatar
yeah... jsut sprayig a lil bit into intake too cool charge and resist ping
Old Feb 13, 2006 | 02:47 PM
SS14PSI's Avatar
Can meth AND nitrous be injected or do you have to choose one or the other?
Old Feb 13, 2006 | 02:51 PM
TwoFast4Lv's Avatar
Still looking at it
Old Feb 14, 2006 | 01:36 AM
SS14PSI's Avatar
Originally Posted by TwoFast4Lv
Still looking at it
huh? ...
Old Feb 14, 2006 | 01:57 AM
TwoFast4Lv's Avatar
Still looking at shooting Meth instead of gas with my power adder Now Imay be changing the way I inject the juice so it may just be an addition to the Juice and gas
Old Feb 14, 2006 | 02:10 AM
kgkern01's Avatar
Correct me if I'm wrong, but methanol injection would only be beneficial on a boosted motor and have no effect on an NA vehicle, correct? Just wondering?
Old Feb 14, 2006 | 02:27 AM
TwoFast4Lv's Avatar
In-correct I am going to have to pull out my old kit. I have one of the old Holley kits still in the box never used
At present I am looking to Snow performance
Old Feb 14, 2006 | 04:48 AM
stevemilz's Avatar
I use the "Mr.Freeze" kit from Anderson Ford Motorsports.
http://www.andersonfordmotorsport.com/mr-freeze.html
Old Feb 14, 2006 | 08:45 PM
Jditlfm's Avatar
Is something like this even worth it for a bolt on Lt1?
Old Feb 14, 2006 | 08:49 PM
Dragframe's Avatar
cooling the intake is always benificial.... jsut how much it will help, i have no idea.
