header question
Old Feb 17, 2006 | 09:00 PM
97blackz28's Avatar
Default header question
i have a 1997 z28 when i bought it it had short tube headers on it, with the stock y pipe and cats. i want to get either a better flowing y pipe but all i can find is the random tech which is a little much at almost 600. are there any other options for a ypipe to mate up to my shorties? i really want LTs but i have to deal with emmisions, my question is with obd2 they do not do a sniffer test just plug into the diagnostics port so if i got a set of LT headers and a ory and had my mad28 pcm tune to eliminate the rear o2s and eliminate the cat would i be able to pass the plug in test or do i have to have the cats? i need your opinions here i have done a lot of searching but can not decide what to do. if i got mid lengths is there any y pipe that i can get that will flow better and sound better than the stock y pipe.
Old Feb 19, 2006 | 03:55 PM
sdm1234's Avatar
You sound like you're in the same situation I was in about a month ago. I live in NJ and I'm not sure if I can trust everyone else's opinion on passing the emmissions test with LT's. And I'm definitely not going to rig up my exhaust to cheat through the test. So, what I did was buy PaceSetter Mid-Length Headers (which fit directly in place of stock manifold), and a Random Tech dual-catted Y-Pipe (which matches with the headers, and matches the rest of the exhaust). I can't find any other catted Y-Pipes that fit underneath a '97 other than Random Tech and Stainless Works. I just got my Random-Tech Y-Pipe for $550, which is a pretty good price (if you're still willing to pay that much).
Old Feb 19, 2006 | 04:20 PM
Camaroguy22's Avatar
Don't spend all that money on a choked up catted small exhaust. If you are OBD-II you can basically do whatever it is you want and just have codes deleted out of your PCM and you will be fine.
