need help
Old Feb 19, 2006 | 07:51 PM
slolt1's Avatar
Default need help
what is the best way to remove the water pump shaft and bearing assembly from the block and do i need to remove the intake to do it
thanks brad
Old Feb 19, 2006 | 08:10 PM
mike2244's Avatar
the shaft slides right out after you remove the water pump
Old Feb 19, 2006 | 08:11 PM
mike2244's Avatar
the shaft slides right out after you remove the water pump now the gear and bearing you will have to remove the timing cover.
