tranny cooler lines leaking?
Old Feb 21, 2006 | 11:07 AM
m3thod's Avatar
Default tranny cooler lines leaking?
ahight, the 2 lines on the passenger side of the transmission are the cooler lines right? its a 96 if that helps. i read that you can just take the whole system off as the stock system is prone to leaking and other crap. i tried to take it out once before but there is supposed to some kind of adapter where the oil filter is right? well mine dosn't have that so ........
Old Feb 21, 2006 | 12:19 PM
dhdenney's Avatar
I swapped in an auto on mine so I'm not too familiar with stock setups. You are planning on running a cooler right? You have to have a tranny cooler or you won't have a tranny very long at all. I just ran two power steering hoses out of my tranny and ran them up to the front of the radiator to two transmission coolers. Where do the stock lines run?
