problems on 95 corvette with tcs
Old Feb 21, 2006 | 07:17 PM
NosFed99z28's Avatar
Default problems on 95 corvette with tcs
my dad has a 95 corvette and the tcs will not go off even sittin still sometimes the cruise wont work either if anyone could help find the problem me and my dad would be greatful.
Old Feb 21, 2006 | 09:02 PM
aboatguy's Avatar
Are you talking about the ASR?
Mike
Old Feb 21, 2006 | 09:14 PM
BizZzatch350's Avatar
Moderator
Mike
I'm sure thats what he meant to say, same difference
Old Feb 21, 2006 | 10:28 PM
Steve40th's Avatar
Check the vacuum lines under the black ASR box, its a little hose connection.
And check the vacuum lines to the Cruise control vacuum under the ECM right above the battery as they corrode easily.
Also, turn the car off and stereo, roll up the windows and start the Vette, then slowly pull forward and you should hear a grinding noise behind the drivers seat, if you do then the ASR is good. It is the valves in the ASR correcting them selves for operation. Now, there is a button underneath the headlight switch which looks like a little Vette laying rubber. Pushit and see if the ASR Off light comes on. If all this is checked and nothing looks bad or you dont hear the valves working when you first drive off you might need to go further into troubleshooting.
Let me know everything that you do, Steve
Old Feb 21, 2006 | 11:07 PM
yes thats what i was talking about thanks for the info ill let you know if it works
