any free mods
any how to do pictures or write up?
i would suggest against this mod. 94 was the first year to have a MAF.
it has to do with flow. the MAF is the instrument that measures the air entering your engine. the MAF elements barely see any area at off of the actual air that's coming in. this means that to get an accurate reading the flow must be laminar (smooth and even) so that the airflow across is predictable.
the screen itself poses much less of a restriction than the throttle body and therefore will not result in a real gain. the gains that ppl see, if any, are due to the now unpredictable airflow. sometimes the MAF can think there is less air going into it than there actually is and lean out the mixture resulting in a little bit more power. if you want to do that just get a tune.
anyway, it's a critical piece of equipment and gains are negligable at best. if you don't understand it, your best bet is to leave it alone.
I have found the left side hose to be a PITA but it helps if you undo the nut holding that pipe to the intake stud, lets you move the pipe a bit and get a long pair of needlenose on that clamp, might need to cut the hose off the pipe then, just have the hose that used to go to the right ready to put on the pipe immediately to minimize coolant spillage.
