ignition options for heads/cam lt1
Old Feb 22, 2006 | 11:56 AM
Formula69's Avatar
Default ignition options for heads/cam lt1
im a little stumped on what kind of ignition products i should go with for my new heads/cam/intake setup... its stock ported heads and intake with a 230/236 comp cam... my main concern is having it not break up at all up top.. the car wont be seeing any forced induction.. there is a lot of talk about all this delteq and ltcc stuff but i was hoping i could just stick with the stock opti and get an msd box or something... think a 6al will work or should i go digital 6 plus? what are the advantages and disadvantages of both.. and if anyone has any good reason why i need a delteq or ltcc let me hear it! thanks!
mods include ported heads, intake, cam, 58mm tb, longtubes with mufflex exhaust, and ram air #30 injectors and a blaster coil
Old Feb 22, 2006 | 12:34 PM
drumbo87's Avatar
I have a full bolt on lt1 with 100 shot of NOS, and i have never had any trouble with my ignition set up. Pulls fine with no break ups to 6800. I have the jacobs Firecontrol 2000 box and the c4 coil. With the use of a secondary trigger this is a plug and play system. Installation was an hour, most the time was spent finding room to mount a box in the already crammed engine bay. You can check them both out at www.jacobselectronics.com
- Jayson
