Airbag light
Old Feb 25, 2006 | 10:48 AM
azazle's Avatar
Default Airbag light
Hello everyone. Before i put the T/A away for the winter the airbag light would flash when started but would remain on while the car was running. I did a search and someone I guess spoke about it being related to the seatbelt not clicked in but that doesn't seem to be the case. I don't have the slightest clue where to begin so any help would be great.
Old Feb 25, 2006 | 11:45 AM
Camaroguy22's Avatar
The seatbelt has its own indicator as far as I know. Have you tried to see if the fuses are all pushed in, also there is a yellow connector underneath the steering wheel behind the kick panel that might be a little loose. I am not a airbag expert by any stretch of the imagination but those might help a tad
Old Feb 25, 2006 | 07:00 PM
HBHRacing's Avatar
it's not tied into the seat belt indicator. Only way you will know whats going on is to have a shop pull codes for the air bag system. Could be anything from a fuse, impact sensor, clockspring, etc etc
Old Feb 25, 2006 | 08:40 PM
azazle's Avatar
Thanks guys when i get a chance i'll take a look at it.
