Accel Opti
Just wondered if you could replace the cap and rotor without having to do as much work as a full opti replacement.
I will likley replace it if do have to do same amount of work either way.
Car is under the snow in storage so can't go look at it right now.Have glanced under there but not really looked at it all that close.
IMHO, it's much easier to just change the whole opti. That reman I had mentioned was actually a reman optical (low res side) and I had to buy a cap and rotor kit (high res side). And putting that thing together was a bitch cuz it didn't have the bolts with it so I had to reuse the old ones. I ended up going to the dealer to see if they could loan me a socket for taking them out. The local parts stores didn't carry anything like that. I think those little suckers are 3mm 12 pts or something.
My point again is just this. If you take care of something it will last. Sure you will have a premature failure now and then. But people just don't seem to care about the opti. They drive thought high water, let the water pump leak all over it, pressure wash the car, let the vent lines fall off, let oil leak all over it etc etc. there is no doubt that if any other cars distributor was drug through the mud like this, it would fail too.
Just so you know guys. The 2L Nissan motors have a distributor much like ours (dual photo emitter and shutter wheel), I belive the same company even makes the electronics for it. Guess what? They are prone to failure as well due to oil contamination that they often get.
The opti is a great idea, with poor (typical GM) execution.
I thought for sure that it went due to the water pump leaking, but when I pulled it apart I found that the metal part of the rotor had almost completely separated from the plastic "melt tabs" that hold it down.
I replaced with a new GM unit, and had no problems for a while... Then the new one went out within 10k miles. WTF?? When replaced and the problem one was opened up, I found that the one of the screws holding the rotor down had come out completely, allowing the rotor to make contact with one of the points and start breaking stuff.
On my new motor, I bought a brand new opti, opened it up, and locktite'd the rotor screws, then super glued all around the head of each screw ... Then put a small bead of gray high temp rtv along the molded silicone seal before re-assembling the opti.
IMO, I essentially 'bulletproofed' the opti against most of the failures Ive had or even heard of people having in the past. Well except for the instance of the metal part of the rotor seperating from the plastic. I couldnt figure out any way to improve that without throwing off the balance or weakening it.
The optis are good, and accurate, just in a bad location. Ive had no more problems with the opti than Ive had with std distributors on other cars.
HBHracing: The optical encoder is made by Mitsubishi on the GM optis... Both the MSD and accel are supposed to use a different brand.
Accel and Mallory are sister companies, part of the MR GAsket groun, who now also owns Jacobs ignition.
MSD is it's own company, and they own Superships now
