new tc
Correct me if i'm wrong, but if you're putting a lockup converter into(i'm assuming) a 93-97 f-body, you will not need a switch of any kind, it will still be controlled by the car's computer. As long as you don't get a cheep *** ebay converter that just has the turbine and pump spaced, you should be fine. 2400 will be a great improvement over stock, and still very streetable... if noticed at all during city driving.
There's plenty of cars running around with high stall converters and those gears....
Yes the PCM controls lock up and unless you want to burn the trans up w/excessive heat at highway speeds I highly recommend going back with a lockup converter.
I am 100% sure Edge can do this and fairly sure Yank or Vig would as well.
