turbo lt1
Old Mar 4, 2006 | 07:25 PM
hardtohitme7's Avatar
Default turbo lt1
are there any turbo lt1 guys out there? if u are can you post your setup and numbers, also if you can post pics it would be appreciated
Old Mar 4, 2006 | 07:34 PM
Camaro_freak's Avatar
I've got an STS turbo setup. Numbers and setup are in my sig.
Old Mar 5, 2006 | 10:09 PM
fabgmc4me's Avatar
My car is in the process of a 383/Turbo build. GMR Speed is building the custom single turbo kit for the car.
It will have a front mount intercooler, and a t76 turbo. I'm looking for around 600 HP.
They will have the LT1 Turbo kit avaliable for purchase in the next few months.
Old Mar 5, 2006 | 10:12 PM
Speed Density's Avatar
hashtagBMW
My buddy is running a 355 with a turbo he is lookin at around 525+ rwhp on trick flow heads.
Old Mar 5, 2006 | 11:19 PM
thanks guys
Old Mar 5, 2006 | 11:35 PM
Frans96SS's Avatar
the fastest lt1 in the world is turboed....
Old Mar 6, 2006 | 12:21 AM
TwoFast4Lv's Avatar
Still toying with the idea. If the car ever goes fast enough they make me put a cage in it...It may just turn into a 427 CI 18* turbo engine....
Old Mar 6, 2006 | 12:23 AM
Ballistic Jello's Avatar
You two that posted numbers, can you tell me what octane you got those figures on? I too am interested in a turbo LT1 setup, front mount or sts..
fabgmc4me, do you know what kind of power you'll be making on pump gas, if that's a high octane number?
Thanks a lot.
EDIT: what's being paid total for an LT1 turbo setup, assuming no intercooler.. ?
Old Mar 6, 2006 | 05:19 AM
Charging TA's Avatar
A friend is building his LT1 to be TT with the Turbolocity (?) prototype kit (from what Ive read there was a LS1 prototype and a LT1 prototype, he owns the LT1 version).
Waiting for him to get it done.
Old Mar 6, 2006 | 08:57 PM
whynot's Avatar
is that on the stock cam and stock manifolds?
Old Mar 6, 2006 | 09:07 PM
whynot's Avatar
Thanks a lot.
single t70 here, upgrading soon, stock 350 didn't last long enough to dyno, little misshap, (didn't like 30 psi for some reason). numbers should be 550+ to the ground, with heads and cam, fully forged bottom end and 8.4:1 compression.
Hands down it would walk away from my supercharged engine seing how I was making 6 psi at 2000 rpm's, verses 6 psi at 6000 rpm's.
as for the cost, minus engine and man hours, it in the neighbor hood of $1,400.00
Old Mar 6, 2006 | 10:05 PM
fabgmc4me's Avatar
Thanks a lot.
I'm looking for those numbers on 93 octane. I 'm not exactly sure what type of numbers I will make, but my estimate is around 600rwhp. The car will be fully built, fully forged internals, 4 bolt splayed mains, custom cam, trick flow heads, upgraded fuel system, ect, ect. I should be able to run some high boost. On race gas I'm not sure what I'll make either.
Old Mar 7, 2006 | 12:32 AM
wolfsburgfanatic's Avatar
I'm guessing at that price its non-intercooled, and you did a lot of the work yourself? Sounds badass, and good luck with the project. I'd love to turbo mine eventually, but a blower is looking a lot more realistic for me.
Old Mar 7, 2006 | 12:53 AM
TwoFast4Lv's Avatar
"whynot" only $1,400? Heck most good turbo's are that alone?
Old Mar 7, 2006 | 01:53 AM
whynot's Avatar
it is intercooled, but I got a great deal on the turbo, just going to have to upgrade soon to a bigger turbo though to make the numbers I want to hit.
I spent
200 on the waste gate and bov,
200 on pipes and header flanges,
200 on intercooler,
and that leaves 800 for the turbo.
Old Mar 7, 2006 | 07:23 AM
Yes, the heads, cam, intake, bottom end, and exhaust are all stock (except for turbo where the muffler was of course). It was tuned on 93 octane, and that's what I always run with.
Old Mar 7, 2006 | 02:53 PM
PipesTA's Avatar
http://www.ls1speed.com/intmd8.cfm
Just depends on how crazy you want to get
Old Mar 7, 2006 | 03:58 PM
I spent
200 on intercooler,
damn, good deal
