what HP from LT's?
Old Mar 5, 2006 | 09:54 PM
87turbo2's Avatar
Default what HP from LT's?
I got my pacestter longtubes and ory this weekend. I hope to get them installed soon. What kind of horsepower gain should I see? Also what kind of power gain can I see from a good tune?
Thanks.
Devon
Old Mar 5, 2006 | 09:59 PM
Speed Density's Avatar
hashtagBMW
10-15 untuned, with a much bigger pull on the top end.
15-20 with a damn good tune.
I think my estamite is off, but thats generaly what they are.
Old Mar 6, 2006 | 12:33 AM
Cchris1109's Avatar
if you have an auto dont get long tubes, get mid tubes
reason being is the long tubes will set next to your A4 thus giving additional heat and having a problem if you like to stomp on the accelerator
i decided that after 2 master mechanics were teaching me about what heat does to an automatic transmission haha
i would rather give up 15 whp on headers then damaging my A4
Old Mar 6, 2006 | 12:43 AM
LT1 Guy's Avatar
Heat will damage more than just the transmission. It will shorten the life of everything in the engine bay. There are ways to get around it--like getting some header wrappers... or not driving around when it's 100+ degrees F. That being said, I've had long tubes in my auto and have experienced no problems with my tranny. However, spark plug wires... that's another story. Oh, and my longtubes don't sit next to my tranny.
Cchris1109's Avatar
yeah im sure thats fine but i figured hey im just losing out on 10 whp and im actually being safe ill just do something else haha
but yeah i mean ive had bad luck with cars so i always play it safe now
Old Mar 6, 2006 | 12:47 AM
infinitebird's Avatar
Plenty of people have autos with longtubes. If they are installed properly this shouldn't be much of an issue.
Old Mar 6, 2006 | 01:10 AM
Vendetta's Avatar
Dude that is a huge amount of bullshit, there are a ton of guys running longtubes with an A4 with no problems due to longtubes... gimme a break.
Once you break into the motor and start modifying internally you'll see so much more gains at the topend with longtubes rather than shorties or midlengths.
You decided wrong.
Old Mar 6, 2006 | 05:24 AM
skatinjay27's Avatar
You decided wrong.
chill out man, dont be such a SPUD
Old Mar 6, 2006 | 09:06 AM
87turbo2's Avatar
Will I see much more since I have a Lt4? I have Lt4 head,intake,knock module, hotcam, 1.6rr, etc etc...I have NO tune and only dynoed 297rwhp. I was really hoping a good tune and these LTs would get me closer to 330+rwhp
Old Mar 6, 2006 | 09:24 AM
Chris 96 WS6's Avatar
On my car, dead stock, FLP longtubes and a cutout gained me 27hp and 28ft-lbs to the wheels...that's BEFORE a tune.
Old Mar 6, 2006 | 02:28 PM
you have the whole lt4 kit(over 2 grand) and those are you r #s and with that set up go with LTS you will see a big difference.
Old Mar 6, 2006 | 02:47 PM
hashtagBMW
Dont get LTs with an A4??? Thats ******* retarted man.
As for the thread, definalty look into getting some longtubes, after making the swap from and open stock y pipe to LTs it was a big big gain up top, but now ive got a little valve float. I would definatly recomend getting Long Tubes, there is no better header unless your using boost.
Old Mar 6, 2006 | 02:49 PM
urbanhunter44's Avatar
Damn you actually bought the LT4 kit?
You'll see alot closer to 330 rwhp with those LTs and a tune. There's also no problem with running LTs and an A4, but if you're really concerned just use heat wrap on the headers.
Old Mar 6, 2006 | 02:56 PM
hashtagBMW
If anything just wrap the collectors, there the closest to the tranny.
Old Mar 6, 2006 | 03:44 PM
StealthFormula's Avatar
yea I have LT's on my A4 and no problems what so ever here. I heard you gains of about 20-30hp with supporting mods.
Old Mar 6, 2006 | 04:07 PM
87turbo2's Avatar
I didnt buy the Lt4 kit, I bought the car in December and the LT4 was already done. Thanks for the input guys. Hopefully I can get these installed this coming weekend and then get some time for a tune and dyno later the next week.
Old Mar 6, 2006 | 06:00 PM
aboatguy's Avatar
If your really worried about the heat use ceramic coated headers.
But I believe its a non issue since the exhaust has to go by the tranny even if you use stock exhaust manifolds. I have had my LTs for more that a year and my ATF temp range has not changed since the install.
Mike
Old Mar 6, 2006 | 08:31 PM
Oh okay, I was getting ready to rip on you for paying for that
Definetly go with LTs, you will NOT be sorry you spent a little extra cash. And if you have to save up money for coating, do it!
