installing 1.6 rr question
Old Mar 6, 2006 | 07:13 PM
silverlt1ss's Avatar
Default installing 1.6 rr question
i'm installing 1.6rr on my camaro and i was wondering if i need new valve springs. i'm not sure that the stockers are strong enough. i don't want a valve float or a broken spring. the motor is completly stock. i know with the factory lt1 cam and 1.6 rocker i will be at 492 and 48? lift.
Old Mar 6, 2006 | 07:23 PM
seawolf06's Avatar
You NEED new springs, retainers and all that. Get some LT4 springs and setup if you don't plan on a big cam ever.
Old Mar 6, 2006 | 11:03 PM
the_merv's Avatar
Veteran: Air Force
You always change the Valve springs anytime you change the Rockers. The LT4 Springs are good all around for many cams, they are a meaty spring..
