electrical problem...won't stay running, HELP!
Over spring break I drove the T/A to Tampa and back--all told 3200 miles logged. Luckily for me, it decided to break after I returned safely to Michigan. I was driving along fine as can be, then the tach starts jumping up and down, engine is backfiring a little. (the engine is NOT going up and down WITH the tach). It's done this once before--I shut it down then started it again and she was fine...not this time. I pulled into a driveway and it dies shortly after the choppiest idle I've ever been witness to. Tried starting it again, but unless I give it tons of gas it won't start, and even if it does she won't stay idling without an obscene amount of gas, which I deemed to be unwise anyway.
My theory: the ground on the engine block is loose? Obviously it has to be something electrical, but where exactly? I've pretty much ruled out the opti since every once in a while I can get a good start without problems.
One probably unrelated problem that happened at the same time: one rib of the serpentine shredded off and managed to jam itself between the power steering pulley and housing, causing a small leak and fine mist of power steering fluid everywhere.
...anybody have a spare power steering pump?
