LT1 Valve Covers
Thanks
Im doing the latter, because it was about $35 cheaper to get a set without a notch and then spend 10min grinding on the back of the altenator.
Ive heard that another option is to use a Powermaster altenator originally intended for a TPI f-bod. They are shorter front to rear, so they'll clear the std. centerbolt covers. You just have to get the high amp version to match our factory pieces amperage output. Factory LT1 altenators I believe are 140amp.
Good luck
EDIT: Mine are part# 6034-1 and they are $99.95 polished.
[IMG] Trending Topics
