AC System Removal
Old Mar 10, 2006 | 11:20 PM
the_merv's Avatar
Veteran: Air Force
Default AC System Removal
I removed my complete Air Conditioning System, because it stopped working, and it had a mojor leak that the previous owner tried to get fixed, but it never got repaired. I removed everything except for the Resivoir in the Fire Wall. I molded that connection with a Dremel, and sealed it off with a piece of Aluminum Sheet Metal, and Silicone sealant, so no heat from the Heating System leaks into the engine bay. I removed the AC Condensor from infront of the Radiator, and it runs 10 degrees cooler. I removed the AC Compressor, and replaced it with the 1LE AC Delete Pully. All lines and Brackets were removed. Has anyone done this also, and what gains did it get as far as power and performance.
Old Mar 10, 2006 | 11:30 PM
HBHRacing's Avatar
there is zero performance gain. The only gain to show is the slight amount of weight removed.
Old Mar 10, 2006 | 11:39 PM
the_merv's Avatar
Veteran: Air Force
From what I noticed so far was it is running cooler, I was just wondering.
