Fuses............?
Old Mar 13, 2006 | 04:51 PM
BlackBirdWs6Zzz's Avatar
Default Fuses............?
When it sits it gets really hot but if i drive the temp goes back to normal (mostly on the freeway) I checked my fan fuse to see if it was just not going on...and i cna't tell cuz it's a BIG black fuse (cant see amything) How can i tell if it's blown?
Old Mar 13, 2006 | 05:02 PM
blkchevyz's Avatar
think your looking at the relay
Old Mar 13, 2006 | 05:50 PM
oh. So the cooling fan switch is................in the dash when you open the door or somewhere there in the fuse box in the engine compartment?
Old Mar 13, 2006 | 07:31 PM
transam5.7lt1's Avatar
Cooling fan switch its located at water pump, that is the coolant temperature sensor, car's PCM gets temperature signal from that sensor in order to turn fans on and off. Fuse block is in the engine compartment, driver side, there you'll see relays for primary and secondary fans. I hope that helps.
Old Mar 13, 2006 | 07:38 PM
I'm sorry........typo, i mean where is the cooling fans FUSE
Old Mar 13, 2006 | 07:46 PM
There's no fuse for the cooling fans..... only RELAYS!
Old Mar 13, 2006 | 07:53 PM
so if my fans are NOT coming on..........how do i fix that? Replace the sensor?
Where exactly is this sensor? I also should check if it's my thermo getting stuck
Old Mar 13, 2006 | 08:04 PM
Like I said on the other thread, run current directly to the fans just to verify their condition. If they work directly... check connections, wiring and relays. If they don't run connected directly.... you guessed right, bad fan motor, probably burnt.
Old Mar 13, 2006 | 10:54 PM
How do you but full current right to the fan?
Sorry for so many questions
Old Mar 14, 2006 | 07:28 PM
Have you seen the fans come on/off? Passenger side should turn on as soon as you turn your A/C on......
