MeLeod Clutch
Old Mar 16, 2006 | 05:15 PM
-PEPE-'s Avatar
Originally Posted by Quick96ss
you can order them in two differnt forms a zero balanced and a regular what did you buy yours for i would buy form the same place you got yours or i will just buy it trom tybrin they have a 10% off deal
Thought the zero balance was an option but wasn't sure, what I bought was an extra new Mcleod twindisc GForce had since Dec, has the clutch, yada yada. I wanted a steel flywheel, this ones alum, but like Joe @T56Rebuilds told me if you've got enough hp/tq it won't matter they both will hold up fine. Think the alum being lighter @rpm helps me on the top end down the track and steel was beasty down low on launching, shrugs either way we'll see. I'd say go with the 10% off thats cool. I saved the cost of alum flywheel because it was just sitting there, it costs letting your inventory sit around. Keep us posted how you like it once installed, will do the same here.
Old Mar 16, 2006 | 05:37 PM
Quick96ss's Avatar
yeah it is an option but what should i buy should i buy the zero balanced one or just get the regular one for my build?
Old Mar 16, 2006 | 05:43 PM
IllusionalTA's Avatar
Well if your ****'s neutral balanced.. get it neutral balanced.. if it's not.. Then get the weight.. it's your call.. use a stock flywheel to balance your rotating assy so you will have no issue w/ the weighted twin..
Old Mar 16, 2006 | 05:55 PM
Quick96ss's Avatar
i was going to have it balanced with my new rotating assembly
Old Mar 16, 2006 | 05:59 PM
Only issue is making sure you assemble it the same way you take it apart.. it's a pretty intricate setup.. lil spacer's and it's very critical that it be put together correctly..
Old Mar 17, 2006 | 08:47 PM
N20Dave's Avatar
Originally Posted by Chris 96 WS6
the Street Twin from McLeod is great clutch but be sure the rest of your driveline (trans, driveshaft, rear) is up to it. the Street Twin doesn't slip....so other parts end up giving...or breaking.
Old Mar 23, 2006 | 12:48 PM
Quick96ss's Avatar
i just ordered my street twin with steel flywheel we will see how it it is. Ill keep you posted when my build is done and my car is on the road.
Old Mar 23, 2006 | 03:33 PM
Good to hear.. you'll be very happy w/ the twin.. Just please understand it's the baddest clutch out for the ltx car's and that it does have it's quirk's.. It's not going to engage "as" smooth as a stocker but will def be alot smoother than any p.o.s spec clutch they have ever made...
Old Mar 24, 2006 | 10:58 PM
Jeremy95TA's Avatar
Purchased one about a week or so ago from T Byrne. It won't arrive until next week. Either way, I can't wait. I'm still stock, but I have a 9" and slicks, so I won't have to worry about the clutch going out though. Although my stock clutch seemed to hold 5k dumps pretty well though. I mean I pulled a 1.84 60' on the stock clutch lol.
Old Mar 25, 2006 | 08:43 AM
Formula WS6's Avatar
Next is going to be your tranny. good luck
Old Mar 25, 2006 | 09:05 AM
TwoFast4Lv's Avatar
The Street Twin is the best LT1/LS1 clutch we can get. It is still kicking LONG after the others have turned to dust
We have installed just about every clutch out there and the twin is what we always go to when the others die
Old Mar 25, 2006 | 03:39 PM
  #32
-PEPE-'s Avatar
Originally Posted by N20Dave
Good point...and on that note, Wednesday I picked up my custom driveshaft. Spicer front/rear 1350 u-joint assemblies 1-3/4" cmoly tubing, Strange 1350 Pinion Yoke with through u-bolts, talk about a beast side by side the stocker. Should have taken pics but forgot to. Joe @T56Rebuilds is rebuilding my T56, tore it down, 2nd & 3rd gears were shot, the rest is all being beefed up along with the Mikronite Surface Finishing. Hope this all holds up along with a 33-splined 12 bolt.
