a/f gauge
Old Mar 16, 2006 | 10:03 PM
YngBird's Avatar
Default a/f gauge
i know you need a wideband a/f gauge to be accurate.but does this apply to both LT and LS cars?or just one?
Old Mar 17, 2006 | 09:06 AM
dhdenney's Avatar
You'll need a wideband to be accurate with anything. The Autometer a/f gauge is just kind of a way to monitor what your O2(s) is (are) doing.
Old Mar 17, 2006 | 02:10 PM
YngBird's Avatar
what makes a wideband more accurate though?
Old Mar 17, 2006 | 02:20 PM
dhdenney's Avatar
For starters it will show you digitally what your AFR is to 0.10, the Autometer A/F gauge merely shows you a series of bars on a scale (with no numbers). Additionally, the wideband uses an independent O2 sensor whereas the A/F gauge only taps into the O2 voltage signal sent to the PCM.
