Trans problem
Old Mar 21, 2006 | 12:00 AM
omaha stylee's Avatar
Default Trans problem
so when i was driving my car i dumped all trans fluid and crop dusted a side street with smoke?????????? i haven't been under the car to look but the car kept driving after this happened for another block until i parked still dumping trans fluid......... anyone have any ideas whatsoever........
also if it is a major problem are the 95 4l60e identical to the 94's?
Old Mar 21, 2006 | 12:14 AM
Timmy2Stage's Avatar
Tenured Member
There is a vent tube on the top of the trans. It will dump fluid out the top if it overheats. Or a trans cooler line got loose/disconnected. See if it dumps tranny fluid when the car is in park at idle.
Tim
Old Mar 21, 2006 | 12:25 AM
Y2K T.A.R.A.'s Avatar
check obvious first, fill and drain fluid
Old Mar 21, 2006 | 03:36 PM
dumped fluid while in park.... lots o' fluid.....found out it is coming from somewhere in the tq converter area....... time for more investigation....... again any suggestions welcome..........
Old Mar 21, 2006 | 04:19 PM
UPDATE cracked torque converter outer casing ................... WTF
