94 Z28 suggestions
Old Mar 21, 2006 | 12:39 PM
nhra_crazy's Avatar
Default 94 Z28 suggestions
Keep or get rid of the a.i.r. emissions are not a problem for me. and do i need to reprogram my pcm
Old Mar 21, 2006 | 02:18 PM
fordeater's Avatar
air is easy to rmove just remove the whole pump itsfelf plug up the intake pipe, and if you have a good air fuse you wont have any ses lights, but there is no point in removing it if you are running manifolds.
Old Mar 21, 2006 | 02:19 PM
slowmofo's Avatar
mine are gone, with no real tune yet and have no ses light
Old Mar 22, 2006 | 12:15 AM
Camaro Fan's Avatar
As I understand it, removing the EGR is supposed to throw the SES in a 94, so I left mine hooked up. I did however disconnect the A.I.R. setup w/ no codes or problems, but that was mainly because I broke the stock tubes trying to remove them from the manifolds during my header swap.
You're not going to gain any power by removing either though, removing the AIR system will clean up the underhood area a little but that's about the only real benefit you're going to get...
Old Mar 22, 2006 | 04:21 AM
slowmofo's Avatar
My egr is also gone with no light, no power gain either. Just wanted it out of the way.
