rockers
Old Mar 21, 2006 | 06:01 PM
NOTAV6's Avatar
Default rockers
do i need anything to support the cc 1.6 roller rockers or can i get them and thats it without anything else and use them or are there some other things in the valve train that i need to get in order to be able to use them i need some help on this asap
Old Mar 21, 2006 | 06:30 PM
30696bird's Avatar
We HAVE to know what size cam you have before that can be anwsered. If you have a cam pushing the springs to the limit with 1.5's then you'll have to have news springs,retainers, & locks. I "think" even with the stock cam it's a good idea to atleast get the hotcam springs (good to .525 lift I believe). They're cheap and pretty easy to install if you're that far into project. JMHO
Old Mar 21, 2006 | 06:39 PM
NOTAV6's Avatar
its gonna be stock cam only difference this motor will have over stock is flat top pistons and the shop that is doing the motor work is going to be doing a long block ill get back in crate assembly so i need to get them the parts pretty quickly
Old Mar 21, 2006 | 06:53 PM
NOTAV6's Avatar
oh and how do i know if i need the 7/16 or 3/8 stud rockers
Old Mar 21, 2006 | 07:14 PM
30696bird's Avatar
Stock is 3/8 stud. If you go aftermarket I would get the 7/16, they won't flex.
Old Mar 22, 2006 | 08:15 AM
NOTAV6's Avatar
with a stock cam so to use the 1.6 roller rockers from cc .... do i need to upgrade the vavle springs and pushrods.. i will be geting new stockers in the engine build
Old Mar 22, 2006 | 04:39 PM
30696bird's Avatar
Valve springs, I would, pushrods are not needed really. Remeber this advice above all........ If you don't do it right the first time you WILL do it again! And the second time will cost more and will probly be harder! That's on all modding not just RR's.
Old Mar 22, 2006 | 09:09 PM
NOTAV6's Avatar
ok so far i am talking to a guy that owns a shop on the hideout and i think im going with 1.6 RR 3/8 studs dont really need the bigger since im not gonna be that much over stock... some LT4 springs since im not gonna be getting that much over stock lift and i can get them for 35 bucks... chromemoly pushrods and some guideplates both from cc
