Injectors?
Old Mar 24, 2006 | 08:09 PM
BarneyMobile's Avatar
Default Injectors?
I was going to go with a set of 36lb injectors for my 383, I keep hearing from some people that I should go bigger like 42lb injectors. I dont kno if 42 will be too big or will 36 be big enough, need some help deciding on which to get. The specs on my motor are.....383, ported heads, 2.02/1.56 valves, 306 cam, ported intake manifold, 58mm TB, Hooker LT's, later I will be adding a 100 shot. what do you guys think I should go with? Thanks!
