ohlt1 gods
i have 42 psi of gas pressure in drive and neutral. help guys. really i need help here
btw. there is no 02 sensors in the car. but i have been ready the car will run fine w/o o2s on a cold start up. and even on a cold start up it does the same thing. the guy doing the tuning said he programed it for a 700r4 instead of a 4l60e. dont know why. but i unplugged the 12/13 plug and same deal. he said it ran perfect in his lt1/6speed. ive been searching for 3 days for someone with a lt1/4l60e car to plug it into <pcm> but icant find one. and im not about to stand outside autozone flashing a pcm in the air until someone stops
Check out ur MAP though and take it to autozone and have them test it.
Gotta take care of the little stuff first and then see what you are left with. until all that is right it is a guessing game
BTW make SURE all the proper grounds are installed or you will have lots of problems!
i have a pcm pinout from shbox.com and ive took my voltmeter. from the battery + to each ground on the harness's that plug into the pcm each ground wire has 12.4 volts on them
also. i just purchased my ypipe. ill be using my hedman shortys and well the hedman y pipe for it. if you run a lt1 with just shorty headers will it do anything to the knock sensor? like make your timing retard?
