hvac delete question
Old Apr 11, 2006 | 06:27 PM
slolt1's Avatar
Default hvac delete question
when removing what are some of you using to plug the hoses off at the water pump thanks
Old Apr 11, 2006 | 08:46 PM
Captainofiron's Avatar
Just get a 3/8ths hose and a union and two extra clamps, thats what I did while my Heater core was leaking. Quick fix, because it is a pain in the butt to change out the core
Old Apr 12, 2006 | 12:59 AM
revtime's Avatar
I used a couple heavy duty vacuum caps and worm clamps.
Its working just fine so far.
Old Apr 12, 2006 | 01:31 AM
thesoundandthefury's Avatar
I bought a 92 Corvette water pump which came from the factory with only one heater hose pipe and cut it off with a carbon cutting wheel then welded the hole shut with Alumalloy. I'm in the process of polishing the pump now but I'll throw up some pics when it's done.
Old Apr 12, 2006 | 10:34 AM
slolt1's Avatar
sounds great if you would
thanks brad
Old Apr 12, 2006 | 11:52 AM
OutlawZ's Avatar
That's the way I'm going to do mine.. (pulling the steel lines and welding the holes shut....)...
Much cleaner and gives you more room to work around the water pump without those two lines sticking up....
Old Apr 12, 2006 | 01:50 PM
trax's Avatar
I would just chop the hard lines, then thread the holes and seal them with plugs. That way if you ever need to tap off the water pump (oil cooler, etc) you can put in an AN fitting or something.
Old Apr 24, 2006 | 04:02 PM
thanks brad
Here you go. The pic is a little deceiving in that it looks like there's a hole there but it's polished Alumalloy:
More pics here: https://ls1tech.com/forums/lt1-lt4-modifications/495010-polished-my-water-pump.html
Old Apr 24, 2006 | 05:15 PM
slolt1's Avatar
thanks that really looks good
