lt1 dropping oil (still)
Old Apr 13, 2006 | 03:50 PM
phrozen755's Avatar
Default lt1 dropping oil (still)
well, just completed my intake manifold gasket replacement (did the whole notorious LT1 manifold oil leak procedure), did that whole thing...only to find out she's still dropping oil...same place, same amount.
She only drops when the car is in nuetral and she's idleing or...when i turn her off, she dumps the mother load...
Im at the end of the line gents....can anyone please help me out?
Old Apr 13, 2006 | 05:50 PM
Captainofiron's Avatar
Where is it leaking from?
Old Apr 13, 2006 | 10:32 PM
buffman's Avatar
did you allow the RTV to cure for atleast 24hrs... Assure all your bolts are torqued to spec in proper order, and that the manifold is not warped??
Old Apr 13, 2006 | 10:35 PM
-PEPE-'s Avatar
definitely check what Buff said and your sure it's leaking from the manifold right? By chance was this an engine swap? Reason I ask is the oil pressure allen screws in the back of the block have to be in tight, missed one of mine once and it poured out. Also check make sure your oil sending unit isn't leaking, driver side behind intake.
Old Apr 14, 2006 | 01:08 AM
buffman's Avatar
if it's on the driver's side make sure the oil filter adapter isnt' leaking either. IIRC the filter adapter on teh F-body is similiar to the B-body and ours usually need a new gasket and o-ring
Old Apr 14, 2006 | 12:37 PM
phrozen755's Avatar
Did what Buff said...thanks so much for the advice!
Checked the back of the manifold...bone dry, checked the oil sender...dry as a bone too...whats freaking me out is....the metal shell protecting the flywheel has the most oil....Im about to say its a rear main seal that went....
If it is a leaky rear main seal, and seeings how I cant drop my tranny in my driveway...I know that certain shops will charge more than others...is it safe to say that in labor, it'll be betweeon $700-$900?
Thanks again gents!
Old Apr 14, 2006 | 01:15 PM
Ls1Bait's Avatar
Yea your making it sound like is is that rear main seal. That will cause it to go down onto the bellhousing cover. Not sure what a shop would charge?
Old Apr 14, 2006 | 01:48 PM
DeltaT's Avatar
For about $45 you can get a leak detector kit with some flourescent dye you add to your oil and a special light. Clean everything as good as you can - even a steam cleaning if possible. Then get the car up on jackstands and have someone do what normally makes it leak. Wear a face shield, and point the light around - the leaky oil will glow like crazy. I found a leak that was driving me crazy. Hot oil moves around so where you see it dripping maybe nowhere near the leak. Pep Boys had it in stock.
At least you will know exactly what is wrong so you are not asking a shop to find it for your $$$.
Jim
Old Apr 15, 2006 | 12:24 AM
buffman's Avatar
could also been oil pan gasket
