Argh! Ticking!
Old Apr 26, 2006 | 10:00 PM
LukePhillips's Avatar
In Need of Cup Holders!
Default Argh! Ticking!
My car has recently devolped a tick. It isn't too loud, but its clearly evident when Im next to something the noise can bounce off of (drivethru's). It seems to go away under acceleration, but it could just be drowned out. But at idle its clear as day.
It seems to be coming directly from the block as far as I can tell. Any ideas? Its driving me nuts.
Old Apr 26, 2006 | 11:05 PM
ZL1SS's Avatar
I would say lifters! Just happened to mine so it's in the shop getting everything new
Old Apr 26, 2006 | 11:08 PM
brickonwheels's Avatar
or an exhaust leak
Old Apr 26, 2006 | 11:13 PM
Cchris1109's Avatar
can you describe this sound, sounds like the same thing is happening to mine, but i think its from the offroad headers im using and the air pump and EGR are still hooked up so its bouncing off
My1st Truck's Avatar
My 94 Z28 ticks as does my 2000 Trans Am. I just live with it.
Old Apr 27, 2006 | 03:19 AM
blue94's Avatar
I'd say exhaust leak(exhaust manifold gasket maybe?) or an arcing plug/wire. Go out in the dark and watch under the hood while the car is running. If you light flashing where the spark plugs are or off of the coil wire right below the intake elbow you probably have a bad plug or wires.
Old Apr 27, 2006 | 04:50 AM
slowmofo's Avatar
Try new gaskets before you try lifters, I had a bad exhaust leak that several people thought was lifters and I replaced the lifters only to have the ticking still there. I would try that first...
