Ring Gear
Old Apr 29, 2006 | 07:20 PM
buttermantoast's Avatar
Default Ring Gear
What size ring gear would a 97 fbody have!!!
Old May 4, 2006 | 10:22 AM
jldak318's Avatar
7.5 dia gear with a stock 10 bolt rear. all u need to know is if the rear is a 2 series carrier or a 3 series carrier. 2 series comes stock with 2.73 gears and 3 series comes with 3.23 or 3.42 gears.
Old May 4, 2006 | 12:07 PM
the_merv's Avatar
Veteran: Air Force
Look in your glove box and see if you have a GU code. It's going to have a number after the GU. Look for the GM CODES thread I posted, and you will find what gear it is.
By Brett Foote | 2026-06-04 05:00:17
