Rev limit on A4
Old May 1, 2006 | 07:05 PM
Cchris1109's Avatar
Default Rev limit on A4
what is the regular rev limit for an LT1 automatic?
Old May 1, 2006 | 07:07 PM
my94blackz's Avatar
5800 i think
30thanniversaryZ28's Avatar
I think mine hits at 6300. Not sure, its been a while since ive hit it.
Old May 1, 2006 | 07:12 PM
Cchris1109's Avatar
ok let me rephrase...when will i lose power on an automatic and it shifting, i thought it was 5700
mine is at 6100 and im losing power at the top end
i could need new plugs/wires though
Old May 1, 2006 | 07:17 PM
my94blackz's Avatar
I got my best times out of my vert by shifting at 6k
Old May 1, 2006 | 07:20 PM
Cchris1109's Avatar
so maybe i am losing power due to plugs/wires/ or even opti
Old May 1, 2006 | 07:46 PM
my94blackz's Avatar
Milage?
Old May 1, 2006 | 07:49 PM
Cchris1109's Avatar
42000 miles
Old May 1, 2006 | 11:22 PM
burnzilla's Avatar
I think its 5700, but dont quote me on it.
I took some buddies up to 145 sunday night, and if I remember correctly thats what it is. I dont floor and hold down my Z very often, but it its around there.
Old May 2, 2006 | 01:17 AM
the_merv's Avatar
Veteran: Air Force
Stock redline is 5700, shift points at 5600. I got mine tuned to redline at 6200, and shift at 6100. The reason you are losing power in the top end is the fact that the engine is stock. I have the Hotcam, that is good up to 6000rpm, and holds power until it shifts, and shifts into the powerband, so it goes like hell... Stock engine is only going to do so much. Cam and Heads help nicely.
Old May 2, 2006 | 10:32 AM
StealthFormula's Avatar
5800 is stock and I had mine adjusted to 6000 in tuning. Kinda strange tho because the other day in the rain I did a huge break burn and I looked at the rpm's and they were at 7000.
Old May 2, 2006 | 01:56 PM
the_merv's Avatar
Veteran: Air Force
Didn't know the Tach said 7,000....
Old May 2, 2006 | 05:40 PM
Dragframe's Avatar
sure does...
well i need to know when the stock rev limiter is at on a 96 TA because i want to put my Mallory limiter 100 rpms before that..
Old May 2, 2006 | 07:11 PM
C_Rules's Avatar
i hit mine the other day and it was 6300 and thats with no tuning.
Old May 3, 2006 | 02:07 AM
the_merv's Avatar
Veteran: Air Force
Yea, that's the last number on it. That's screamin at 7,000 rpms..
Old May 3, 2006 | 01:04 PM
1994Z28Lt1's Avatar
my first every outing to the track i pulled up to the waterbox and gave her hell..... rpms went straight to the limiter it was bouncing around in the 6-6100 area
k nevermind you did say for autos i dont know if they are any different for m6's
Old May 3, 2006 | 03:36 PM
Dragframe's Avatar
i know bryan or whatever from psmforless says it is at 5700-5800 and auto trans shifts at 5600 at the latest (regardless of what your factory cluster tach is saying.. cuz they are inaccurate anyways)
