Where is the knock module?
Old May 7, 2006 | 08:13 PM
jst's Avatar
jst
Default Where is the knock module?
help...
Old May 7, 2006 | 08:25 PM
-PEPE-'s Avatar
midway, pretty sure it's on the passenger side of the block for the actual module, the sensor is located on the belly of the PCM.
Old May 7, 2006 | 08:53 PM
Honda Hunter's Avatar
I believe you have it mixed up brett
Old May 7, 2006 | 08:58 PM
slowmofo's Avatar
the module is on the back of the pcm.
Old May 7, 2006 | 09:16 PM
94greencamaro's Avatar
Yep, just unscrew the four screws holding the plate on and there it is.
Old May 7, 2006 | 09:53 PM
-PEPE-'s Avatar
your right...when I installed my LT4 knock module it went in the pcm...so the sensor is on the block...guess that makes sense...
thanks man
Old May 7, 2006 | 11:30 PM
BizZzatch350's Avatar
Moderator
Yep, the sensors in the block, it likes to give coolant showers when it comes out of the block to be changed.
Old May 8, 2006 | 03:19 AM
LT1BRN's Avatar
any write ups on how to install the LT4 knock module?
Old May 8, 2006 | 05:56 AM
There are like a million. Heres what I used -----> http://www.fbody.com/tech/details.cgi?id=10
