shorty header install update
drivers side manifold wasnt too bad to remove. just a bit time consuming. none of the bolts were truely a PITA.
tryin to get the new header in the drivers side and the steering linkage is all in the way. i gave up on that and moved on to gettin passenger side manifold off.
got all but 2 bolts off on that one right now. the furthest to the firewall bolt broke off.
i was quite pissed about it. it was the only bolt i didnt pb blast, and thats why it broke i suppose.
the 2 bolts that are holding it in right now are already loosened, just not out yet. i have 2 more afternoons to work on this car before it needs to be done.
Im just hoping i can get it all done in time
cough*hammer*cough because they rust on there a bit then just work it back and forth and the bottom part should come off first then you can just slide the upper part off of the steering wheel shaft coming thru the firewall, you can do it, just takes some time and finesse and patience I'm gonna get it fixed at a shop. How hard do you guys think it is?
That sucks about the broken bolt, I was very fortunate that none of mine broke off or stripped the holes in the heads. Only stuff that broke on mine were the studs for the stock y-pipe flanges to mount up to the stock exhaust manifolds, no big deal. I imagine it will be a bear to get that broken bolt sorted out depending on exactly how/where it broke off...
Stupid y-pipe bolts broke on at the cats and it hit me in the head lol.
Did you guys know that y-pipes fly like boomerangs? The air pissed me off too. That last bolt just wouldn't come out so I ripped the air out. Yeah I punted that sumbitch. Steeltoe does a number on that piece.
