500rwhp
But if you dont wanna go that route.
Afr 227's
solid roller
maybe a carbon fiber drive shaft
Afr 227's
solid roller
dont forget to get a hypertech power programer
It's gonna take alot of work to put down 500rwhp. What I was trying to point out was just an example of something small that squeze out acouple more HP, and a CF driveshaft would yield a couple of Hp.
even a tornado!!! JK ****
Look no further.
Whatever you do, don't listen to bret. He's a
Bret
I curently make 425 rwho, with a modest cam and a 396. I now AFR heads and a better cam will work, but getting an LT4 manifold isnt cheap anymore? How about a Edlebrock EFI Victor manifold? WIth an ELbo style adapter to fit a throtle body? Sorry for so many questions.
I've seen the Vic EFI intake and it's a pile IMHO. It does have the injector bosses in it already but it needs WAY too much port work to get it done for you. Plus it's super heavy, a Super Vic when it's done will come in at 1/2 the weight.
The intake manifold that I start from on the single planes varies depending on the head castings, TFS/AFR/LT4 all use one while the LT1 castings use another.
BTW that intake that aggie has on that motor is a Super Vic that I did for Jordon Musser last year at some point.
Bret
brook
i had a friend get 480rwhp with an LT1 manifols and AFR heads with a 396. But he had 12.5 to 1 compression and a big solid roller. It idled at 850 rpm though, as it was tuned very well. But the heads were, as well as the manifold, ported beyond recognition.
Dont all the bog flowing AFR heads need the LT4 manifold though.?
i will sonsider sellign the top end if anyone is interested
brook
Look no further.
Shon Herron said he thought that AI could do it with an LT1 intake and well they proved him right. Just a "street ported" intake too.
