ltcc coil mount suggestions
Old May 11, 2006 | 03:39 PM
rob97TA's Avatar
Default ltcc coil mount suggestions
ok guys, i need some suggestions on where i should mount my coils for my ltcc kit im gonna try and install this weekend. I cant put them on the valve covers, because i have pacesetter mid-length headers, and the drivers side header is all wierd and i couldnt fit the wires around the headers without burning them, so i have kinda narrowed it down to either mounting them on the fan shroud, or somewhere under the cowl. Under the cowl would be a major pain in the butt, and on the radiator fan shroud, i could run the wires under the headers like they are stock locations, but i couldnt find any pictures of anyone that has mounted them there. So any other mounting suggestions would be appreciated, thanks. Oh, and making mounts isnt a problem i can make some.
Robby
Old May 11, 2006 | 03:52 PM
-PEPE-'s Avatar
How I'm running mine, should get some actual bolted to an engine in an engine bay pics here in about 12 days or so. They actually will bolt to the intake studs with an ss nut/flat washer, they clear the tall covers and follow the same lines, you could use them on short covers as well. If someone had the traction control motor setup on the driver side valve cover this would not clear.
Old May 12, 2006 | 07:47 AM
Bad Dad's Avatar
Robby
Mines not as pretty but I can remove my valve covers without
disconnecting all the coils.
