my car died HELP!
Old May 11, 2006 | 07:51 PM
Smokey TA's Avatar
Default my car died HELP!
my car just spot turning over. i had the car for about a year and never had a problem. just today i went to start my car it not even moving the rocker arms. it just tick tick tick and my gauge lights flickers. my battery volts are bettween 8 to 13. i can't figure it out. .
it is a 95 Trans AM
Old May 11, 2006 | 07:54 PM
95WhitetopTA's Avatar
Start from the beginning and put a different battery in it,check starter etc check charging situation once its running.
Old May 11, 2006 | 07:57 PM
BlackBirdWs6Zzz's Avatar
SOunds like you have a bad battery, or a bad CONNECTION, check the tighness of the cables to teh battery, that will sometimes cause the "clicking." It's most likely that, if not, your starter.....
Old May 11, 2006 | 09:36 PM
Smokey TA's Avatar
how hard is it to change a starter.
Old May 11, 2006 | 09:46 PM
I have never checked out the starter on a TA or Camaro, should be connected to the trans, hoist it up and take a peek. Shouldn't be too hard. Wiring is pretty simple too.
Old May 11, 2006 | 09:47 PM
Captainofiron's Avatar
its pretty easy to change out the starter two bolts and two nuts for the wiring and BAM its out. Its probably one of the easier fixes, actually I would pull out the starter and the battery go to your local auto parts store and get them to test them, it sounds like a bad starter or wiring hook up, usually a oil soaked starter will do that.
Old May 12, 2006 | 01:23 AM
The LT1 That Could's Avatar
sounds like a starter!
Old May 12, 2006 | 09:02 AM
Billy177's Avatar
well if it drops to 8 volts it is probrally not the starter. my guess it a bad battery and once you get it running be either a new battery or a jump i would check the charging system to make sure that it is charging
Old May 12, 2006 | 02:40 PM
fbodyls1ws6's Avatar
It could be the fuel delivery......like when you put in acc...if you here a click sound were the back seats are that means its the fuel delvery......but you should go pay $80 for a pro to check out your whole car and it takes about a day or maybe 2 days...its worth it....
Old May 12, 2006 | 05:37 PM
Smokey TA's Avatar
i work on it some more today. i can push start it, frist try. And i check my oil and it is LOW i think that oli got into my starter. does that mean New starter or clean the starter and find the oil leak.
Old May 12, 2006 | 05:49 PM
Clean it, see if it does any better, if not, repalce it.
