what Fuel injectors
Old May 12, 2006 | 08:19 PM
Smokey TA's Avatar
Default what Fuel injectors
i don't know how much power u can make off fuel injectors. has anyone notice power out off them. i basicly have a stock motor what sizes should i go. Its for an lt1
Old May 12, 2006 | 08:25 PM
94greencamaro's Avatar
Fuel injectors are not going to increase power. People get larger fuel injectors when they need to get more fuel to the motor (boosted, more cubes, etc.), not when their car is stock.
Old May 12, 2006 | 08:31 PM
Smokey TA's Avatar
i am gonna add 58mm tb with ported intake headers full exaust and more then likely nitrous. do u have a size in mind for that setup
Old May 12, 2006 | 08:51 PM
Well, you dont need the injectors until you add the nitrous, and some dont even add them then. But depending on the shot i would say a 30 lb injector would work. And what all do you have on your car right now. You could probably put the money your gonna buy a 58mm tb with to way better use.
Old May 12, 2006 | 10:58 PM
chris77's Avatar
like said before injectors dont make more power and you will only need em if the no2 kit you chose is a dry kit if its a wet kit then your stock injectors are fine.
