help please!!
Old May 13, 2006 | 08:45 PM
LUCIFERII's Avatar
Default help please!!
k guys heres when the problem started when i had a nitrous back fire at the track. then put the car on the trailer and took it home then the next day i turned it on and it was on fine till i turned on the a/c and it started acting up and then shut off. then when i tried to turn it on again it will only fire up at wide open throttle only. as if it was flooded then sure enough we pulled the plugs and there filed out. put on a new set and fired up fine then after using it for about 30 minutes it started acting up again and shut off. car flooded again. we checked the plugs and sure enough there filed out again. so we check the fuel pressure and it was fine at 40 psi car would run perfect on it before. then we put a new disributor and nothing. car will start at wide open throttle only and bogs when you floor it. my guess flooded but why does it keep doing this ????
Old May 13, 2006 | 09:55 PM
aggiez28's Avatar
thats what ya get for having a name like lucifer
Old May 15, 2006 | 12:49 PM
LUCIFERII's Avatar
lol you dont know how many times ive heard that. lol but seriously i need help bad
