any 93's out there
Old May 14, 2006 | 08:09 PM
Kanes2413's Avatar
Default any 93's out there
IM about to add a full exhaust and others. I'm wondering if anyone with a single cat setup had any work done, if so what was it and how was the ground clearance. I was under the car all day and kept looking and cant figure out how this stuff will fit and still be driveable FYI is pacesetter LT's ORY and hooker together thanks
Old May 14, 2006 | 09:43 PM
1993BlackZ28's Avatar
well my buddy put pacesetter lt's on and they seem to have decent ground clearance as for work with the ory and cat, yes , work needs to be done as the ory doesnt come with a cat so it has to be cut and welded.
what ive heard is that you go cat-less the pacesetter and ory should fit well together with a cat-back system
i was looking into finishing my exhaust off. right now i have just borla cat-back. thinking of going pacesetter lt's (jet hot coating) with an ory
Old May 14, 2006 | 10:32 PM
smoknta's Avatar
If you are looking for 93 specific info, you should check out www.speeddensity.org
This is an awesome site, buy you may get some mixed results when looking for 93 specific info.
Old May 14, 2006 | 11:32 PM
Speed Density's Avatar
hashtagBMW
I second that.
Old May 16, 2006 | 08:14 AM
93BlackZ's Avatar
Originally Posted by Speed Density
I second that.
i make it 3rd, speeddensity rocks!!
Old May 16, 2006 | 10:46 AM
BizZzatch350's Avatar
Moderator
Good luck man, it will come together, I still look at my LTs and wonder how the hell they got in there. Tight sqeeze but they will go.
Old May 16, 2006 | 11:22 AM
ls1charged's Avatar
can anybody tell me what the downsides are compared to having MAF to speed density if there are any?
Old May 16, 2006 | 11:23 AM
Moderator
93s are harder to tune so you have to burn chips.
Old May 16, 2006 | 11:26 AM
hashtagBMW
But 93s arent such a PITA for emissions and SES codes.
Old May 16, 2006 | 11:31 AM
ls1charged's Avatar
thats always a plus.
and is speed density the reason that they only make certain stuff for certain years. like 93 to 94 diffs.? or is there actually other differences?
Old May 16, 2006 | 12:09 PM
Moderator
Yeah, theres a couple differences, Fuel presure regulator, air/egr hook ups, intake differences, bunch of little things
Old May 16, 2006 | 10:11 PM
93BlackZ's Avatar
check speeddensity, in the engine section theres a sticky and itll answer all the questions you have
Old May 16, 2006 | 10:27 PM
ls1charged's Avatar
ill do that, thanks
