Fel Pro Header Gaskets?
Old May 15, 2006 | 07:29 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default Fel Pro Header Gaskets?
Are these any good? Its all I can get local, are they any good?
Old May 15, 2006 | 07:42 PM
DirtyBird222's Avatar
as stated in my other thread, they suck. Not even a whole year and one has blown already.
Old May 15, 2006 | 08:05 PM
Sgt. Spuds's Avatar
I just went out and snuged all my driverside header bolts up some, but still the noise perseists... I think its coming from the collector...
How hard is a collector gasket?
Old May 15, 2006 | 08:16 PM
a lot easier. 3 bolts usually, once you got them off jiggle the y-pipe off of the collector and the gasket should fall out
Old May 15, 2006 | 08:19 PM
Sgt. Spuds's Avatar
its a 2 bolt... But IDK what gasket to get? what type the BBK headers use, I know its sa 2.5 inch collector..
Old May 15, 2006 | 10:43 PM
Hot94Z28's Avatar
I thought they were a slip fit and you put high temp silicone around it and slid the y-pipe on it and tighten the bolts
