Difference between the L98 and Lt1?
Old May 16, 2006 | 02:01 AM
birdman92's Avatar
Default Difference between the L98 and Lt1?
Is it the same block different intake or what? im confused
and if it is the same block could you throw a Lt4 cam in an L98?
Old May 16, 2006 | 08:39 AM
JimboManJones's Avatar
The block is almost the same, different cooling passages I think, intake is defintely different.
Yes, you can use a lt4 cam in an l98.
Old May 16, 2006 | 09:43 AM
the_merv's Avatar
Veteran: Air Force
L98 intake is different. The LT1 is the first engine that's Reverse Cooled.
Old May 16, 2006 | 10:28 AM
aboatguy's Avatar
There are differences in the machining on the front of the block too! IE the water pump drive.
Mike
