fuel pump?
Old May 19, 2006 | 09:19 PM
J_BAT's Avatar
Default fuel pump?
wut kinda fuel pump does my car use, and how would i install a new one . on a scale of 1 to 10 how hard would it be
Old May 19, 2006 | 10:15 PM
9formula4's Avatar
it is simple. You would use an intank pump. Make sure it is for the f body of your year. Summit racing sells them and you can find them online also. Racetronix.com is a good one from what I have heard
Old May 19, 2006 | 10:26 PM
J_BAT's Avatar
well i was givin a fuel pump. its a NOS pump and has tubes comin out of both ends and two metal **** to hook up power. and is covered in black thick foam. just discribing wut i see, and a metal bracket.
Old May 19, 2006 | 11:17 PM
rob97TA's Avatar
from the way u describe it, it doesnt sound like a in tank pump, from the foam around it mainly
Old May 19, 2006 | 11:20 PM
the_merv's Avatar
Veteran: Air Force
The fuel pump is in the tank, and if you have a Dremel handy, you can make an access panel on top of the tank in the back of the car, and change it in 5 minutes.
Old May 20, 2006 | 05:10 PM
J_BAT's Avatar
well it doesnt need to be changed i was just givin this aftermarket fuel pump and wondered if it will work, sounds like it wont though
Old May 20, 2006 | 05:38 PM
93BlackZ's Avatar
i just did a fuel pump install, you can use a dremel and cut a hole, easier then dropping the tank. i used the granatelli, it took a lil bit but i got it, just take your time and youll be fine
