valve adjustments?
SO, this pretty much suggests that the valves are fully closed and the lifters weren't bottomed out. BUT, say I did want to try and run less preload, how would I go about this, because if you think about it at this point the lifters are NOT completely full of oil and up, they have just bled down to where they need to be at this valve adjustment. So, right now if I were to pull off the set screw and turn the valve to zero lash (where the pushrod no longer spins) I would only be tightening the valves being the the pushrod is spining while the rockers are adjusted. IS THERE A WAY TO BACK THE NUT AND SET SCREW OFF THE ROCKERS AND GET THE LIFTERS TO FILL BACK UP SO THAT I COULD APPROPRIATELY ADJUST THE VALVES?
Any other ways to get the lifters to fill backup once i back the nut up?
