quick radiator question.. URGENT
if i can plug it tell me... if not... i guess i will try to figure somethin out....
1) As far as flow of the stock system, refer to these diagrams:
http://lt1info.com/TECH/Cooling%20Sy..._radiator1.gif
http://lt1info.com/TECH/Cooling%20Sy...ms/DSC1272.gif
http://lt1info.com/TECH/Cooling%20Sy...tor_hoses1.gif
http://lt1info.com/TECH/Cooling%20Sy..._coolant_1.gif
2) You MUST keep that steam pipe active. Since it is an outlet from the heads, you'll probably want to connect it to an INLET on the radiator (but not an inlet to the waterpump, as you don't want to introduce any steam/air pockets back into the system). This would entail that you 'tee' into the radiator inlet hose -- either making your own fittings, or purchasing a fitting intended for this purpose. I don't have a link handy, but I know there are manufacturers for this.
3) We were having this discussion on another board, and it turns out that the waterpumps in the Vettes/Fleetwoods/etc don't have the waterpump fitting on the bottom driver's side. As such, you could try purchasing one of these specific pumps, or otherwise block off your fitting entirely. I don't believe this will present any problems with flow. You can see what I'm referring to BY CLICKING HERE.
Not sure how much that helps, but it's a start. Hit me back with your thoughts, as I'm not there to see what exactly is going on (-and I have a 1994 with different hose routing).
Part # Year Model Inlet Outlet Rows
Tube Size Additional Information
6-293AE-GAX 93-96 Camaro LT-1 outlets 2 row, 1.0" X X
6-293AE-GXX 93-96 Camaro LT-1 outlets 2 row, 1.0" X
6-293AE-BAX 93-96 Camaro top left bottom right 2 row, 1.0" X X
6-293AE-BXX 93-96 Camaro top left bottom right 2 row, 1.0" X
6-593AE-GAX 93-96 Camaro LT-1 outlets 2 row 1.25" X X
6-593AE-GXX 93-96 Camaro LT-1 outlets 2 row, 1.25" X
6-593AE-BAX 93-96 Camaro top left bottom right 2 row, 1.25" X X
6-593AE-BXX 93-96 Camaro top left bottom right 2 row, 1.25" X
Everyone said the side that the thermo is on is always top???
if someone could verify which hose goes to the top and what goes to the bottom so i can fill her up with coolant and go... i would appriciate it!
thanks..
this baby really cools. Works good... so im pretty satisfied... will take pics tomarro..
